TLE5012B (SSC SW) on VESC 60/75 MK2 – sensor never responds, ~99.99 % SSC error rate
France13
Last seen: 1 month 3 days ago
Hi everyone,
I'm trying to get a TLE5012B magnetic encoder working on a Trampa VESC 60/75 MK2 (firmware updated to the latest version via VESC Tool), but the sensor never responds.
Setup
  • Sensor: TLE5012B E1000 breakout (cross-shaped board, two 5-pin connectors: P1 = SSC, P2 = ABI). The module has series resistors on the SSC lines (470 Ω on DATA, 100 Ω on CSQ and SCK) and 2.2 kΩ pull-ups on IFA/IFB/IFC.
  • Sensor Port Mode: TLE5012 Encoder (SSC SW)
  • Wiring on the SENSE port (according to encoder.c: PIN1 = SCK, PIN2 = MOSI/MISO, PIN3 = NSS):
    • V+ → VCC
    • H1 → SCK
    • H2 → DATA
    • H3 → CSQ
    • GND → GND
  • Diametrically magnetized magnet, Ø6 mm, air gap tested at 1.5 and 2 mm
Terminal output (encoder)
  • SENSE port, SSC SW:
    Last error: 1, ssc error rate: 99.985 %, magnet strength: 0, temp 54.76 C
  • COMM port, SSC HW (MOSI/NSS/SCK):
    Last error: 255, ssc error rate: 99.986 %, magnet strength: 1, temp 54.39 C
As far as I understand the code, 54.76 °C corresponds to a raw temperature of all zeros and 54.39 °C to all ones — so the VESC only reads the idle level of the data line and the sensor never answers.
What I have checked
  • 5 V directly at the sensor chip (across the decoupling capacitor)
  • Continuity of all wires, cable plugged into the SSC connector (DATA reaches the 470 Ω resistor)
  • Swapping CSQ and SCK: no change
  • Realtime data working, battery voltage 15.6 V, no fault code
Questions
  1. Has anyone successfully run a TLE5012B in SSC SW mode on the SENSE port of a 60/75 MK2? Could the input filtering on the hall lines combined with the 470 Ω series resistor on DATA prevent communication?
  2. Should I bypass the 470 Ω resistor on the module?
  3. Is the COMM port test meaningful at all, or are MOSI/NSS shared with UART TX/RX on this board?
Thanks a lot!
