Powebutton LED Magenta/Pink
Keksfox
Hello all!
Today i set up a new Duet XS 60V. Running on 10S2P P50B cells, powering two flipsky 6478 outrunners, intended for an eskateboard.
Motor detection ran without issues. However, i have noticed the powerbutton only shows magenta, not green. Its not flashing, just constant magenta. It only shows green briefly during startup, so its not the green LED gone. There are no faults, according to the Vesc tool. The "internal" LEDs on the PCB are showing blue and green only, as far as i can tell.
Anotherthing is, my esp32 cant seem to read any data via UART from the Vesc. It is set up in the app settings and the baud rate is set up correctly as well. I dont know if these "issues" are connected, the data reading might very well be my coding, its definitely not final yet...
What does the pink powerbutton mean?
Best regards! Jan
