I have a flipsky 75100 pro v2 getting wired up to a large motor. I have purchased a as5048 encoder board by AMS
Does anyone have tips on how to wire this to the 75100 pro? I see a most reference the as5047. This board fits the hardware better.
Any help or links appreciated.
Im need to do the same, any News?
Heres what I found.
Connecting an AS5048 magnetic encoder board
to your
Flipsky 75100 Pro V2
requires linking the sensor's SPI (or ABI) lines to the ESC's sensor/auxiliary port and configuring it in the VESC Tool
Step 1: Pin Mapping (AS5048 to VESC Sensor Port)
The sensor port on the ESC typically provides 3.3V (or 5V), GND, and the SPI bus signals (
SCK,
MOSI,
MISO,
CS). Check your specific AS5048 breakout board layout against the standard SPI definitions: [1, 2]
Connect to 3.3V (or 5V if your AS5048 board includes an onboard voltage regulator; double-check your board spec—usually 3.3V from the VESC is safest).
Connect to GND on the ESC.
Connect to SCK (SPI Clock) on the ESC.
Connect to MOSI (SPI Master Out/Slave In) on the ESC.
Connect to MISO (SPI Master In/Slave Out) on the ESC.
Connect to CS (Chip Select) on the ESC.
[1, 2]
Tip: If you are using a diametrically magnetized magnet, make sure it is mounted centered directly over the center of the AS5048 IC chip with a proper air gap (typically 0.5mm to 2mm depending on the magnet size).
