Flipsky 75100 v2 pro
Figjam007
VESC Gold
I have a flipsky 75100 pro v2 getting wired up to a large motor. I have purchased a as5048 encoder board by AMS
AS5048B Hall Effect Sensors for Teensy 3.6 issues getting data. - General  Guidance - Arduino Forum
Does anyone have tips on how to wire this to the 75100 pro? I see a most reference the as5047. This board fits the hardware better.
Any help or links appreciated.
Zebaztiann
Last seen: 3 weeks 1 day ago
Im need to do the same, any News?
VENTURI
Last seen: 2 weeks 15 hours ago
VESC FreeVESC Platinum
Heres what I found.
Connecting an AS5048 magnetic encoder board
to your
Flipsky 75100 Pro V2
requires linking the sensor's SPI (or ABI) lines to the ESC's sensor/auxiliary port and configuring it in the VESC Tool
Step 1: Pin Mapping (AS5048 to VESC Sensor Port)
The sensor port on the ESC typically provides 3.3V (or 5V), GND, and the SPI bus signals (SCK
, MOSI
, MISO
, CS
). Check your specific AS5048 breakout board layout against the standard SPI definitions: [1, 2]
  • VDD / Power:
    Connect to 3.3V
    (or 5V if your AS5048 board includes an onboard voltage regulator; double-check your board spec—usually 3.3V from the VESC is safest).
  • GND:
    Connect to GND
    on the ESC.
  • SCK (Clock):
    Connect to SCK
    (SPI Clock) on the ESC.
  • MOSI (A1):
    Connect to MOSI
    (SPI Master Out/Slave In) on the ESC.
  • MISO (A2):
    Connect to MISO
    (SPI Master In/Slave Out) on the ESC.
  • CSn (Chip Select / SDA):
    Connect to CS
    (Chip Select) on the ESC.
    [1, 2]
Tip: If you are using a diametrically magnetized magnet, make sure it is mounted centered directly over the center of the AS5048 IC chip with a proper air gap (typically 0.5mm to 2mm depending on the magnet size).
