VESC 6 MKVI not detected by VESC Tool / firmware version cannot be read
kimyeonjun
I am having a problem with my VESC 6 MKVI and I would like to ask for help.
My VESC 6 MKVI is not being detected properly by VESC Tool, and the firmware version cannot be read.
When I try to connect, it either fails to connect or does not load the device information correctly.
Here is what I have already tried:
  • changed the USB cable
  • tried different USB ports on the PC
  • powered the board from an external battery
  • tried connecting with ST-LINK
  • compared it with other boards, and only some VESC 6 MKVI seems to have the problem
At this point, I am not sure whether this is a hardware failure, firmware issue, or communication problem.
Current symptoms:
  • VESC Tool cannot read firmware version
  • the board is not recognized properly
  • ST-LINK also does not seem to detect it normally
I would appreciate any advice on:
  1. whether this looks like hardware damage
  2. what I should check next
  3. whether I should try reflashing firmware
  4. whether this could be caused by USB/UART/interface damage
If needed, I can also upload photos of the board, wiring, and screenshots of the error.
Thank you.
