Cant get Data on VESC Dash 35B
CommanderLee
I have put my motor and the VESC into operation.
I can connect via WiFi using VESC (station mode) through a hotspot to my computer without any issues — everything is working.
I connected the VESC Dash 35B with +5V, GND, CAN-H, and CAN-L.
It powers on, and I can access the ESP32 of the display using my smartphone and the VESC app.
All firmware updates (6.06) and packages have been completed and installed.
However, I do not see any data on the display.
I have read the manual multiple times without success, which is a bit surprising.
I hope someone can help me here.
My first question would be regarding the CAN bus termination resistors:
Are they already integrated in the devices, or could they be missing and causing this issue?
best reagards
Lee
electricfox
electricfox's picture
Last seen: 14 hours 28 min ago
Is your bluetooth turned off?
Have you updated the packages archive and then installed the packages?
You can always send an email to Vesclabs directly if you have problems.
CommanderLee
Hi electricfox,
bluetooth turned off for VESC, for B35-Display bluetooth on.
Yes, updated the new firmware 6.06 and B35 package on both devices.
I send an email to benjamin.
blackprint
Last seen: 6 months 9 hours ago
good afternoon,
im have the same issue i got everything to work i just cant get the 35b dash to read or comunicate with my ds100
jw sanders
Last seen: 2 days 17 hours ago
Did you use the "Update Archive" button on the VESC Package page in VESC Tool before installing?
