FOC detection.
Last seen: 12 months 2 days ago
FOC detection.
HI,
I again have a motor that VESC-tool will not lambda-detect at all. ben b
I've configured it as BLDC. I have a 1A 12V powersupply for now, so I tell it to go at 0.5A motor current and... voila! there it goes. Somehow, the dutycycle does not go up to 95% as I expected, but lets ignore that for now. It runs.
Next I want to reduce noise, ans get FOC to work. So detect RL and I get 26mOhm and 16 uH. Good. And then... no mater what I try: I can't get it to turn during the lambda-detection. So I have no clue what the lambda is.
I've used the formula: λ≈ 60 / ( sqrt(3) *  poles *  pi * KV) = 60 / (sqrt(3) * 36 * pi * 100) = 3.0 mWb.
When I manually enter that and ask the motor to run I get a squeal from the motor and "absolute overcurrent fault".
So what should I do?
Maybe: Does anybody have the FOC parameters for the FXD 8318 motor? (Even better would be if the FOC detection could be made to be workable for a not-a-noob like me).
UPDATE: I've re-found "measure_linkage_openloop".
I can then give it parameters like 1A or 0.05A, 0.1 duty, 200 ERPM/sec ramp, 26 mOhm , 16 uH and then it trips "overcurrent FAULT". When I drop the current to 0.04 or below, I just get "failed to measure flux linkage". (in BLDC mode the motor draws about 0.1A to run at 50% duty).
UPDATE: I noticed the "setup wizard". That works a lot better than what I'm used to. The motor is detected as 2.11 mWb.
tobiokanobi
Just because I am tweaking on something similar:
Increase the current I in the FOC detection. This helped me.
