BLE Connection Bug
Gawarmel
BLE Connection Bug
Setup: any VESC, Flipsky (or any) receiver, VESC WAND Controller and Vesc Tool 6.06 for android. This is a new bug, not seen with VESC Tool 6.05:
- connect VESC Tool android with vesc over BLE. SEtup Motor. This works perfectly.
- use NRF quick pair to connect VESC WAND Controller. Now VESC WAND works as usual, pairing successful
- disconnect VESC Tool 6.06
Try to reconnect VESC Tool will fail now. Error Message: "This device is not paired to your local version of VESC Tool. You can either "
                              "add the UUID to the pairing list manually, or connect over USB and set the app "
                              "pairing flag to false for this VESC. Then you can pair to this version of VESC "
                              "tool, or leave the device unpaired.
Only way to reset this is USB Connection to desktop version of V Tool and reset the pairing.
How to fix this??
