Battery profiles?
ahagge
Battery profiles?
Is there a way to create "battery profiles", ie. switchable profiles which include battery parameters such as chemistry, configuration (10S3P), capacity, max discharge rate, etc.?  I can't find anything in the profiles that concerns battery information, only motor information.
Use case:  I run multiple batteries on a friction-drive e-bike.  For long flat rides I use a Li-Ion battery with large capacity but relatively low max discharge rate, but if I'm going to be doing hills, I switch to a Li-Po battery with a high discharge rate in order to have the wattage for hill climbing.  I use the same motor in all cases, so the same motor parameters, just different battery parameters.
It would be SO much easier to simply switch battery profiles after switching batteries.
If there's no option, I can submit a feature request, but didn't want to do so immediately in case I'm just missing something.
