VESC BMS problem with LTO Battery
SteveBrantley
My electric supercharger project uses a 32s LTO battery driving a VESC 100/250.    I'm using an  ENNOID BMS which communicates to the VESC across the CAN bus.   If I check Vcell Min under BMS Limit Mode, the motor will not start.  I have Vcell min set to 2.2V and all the cells are well above that.     Is there a way to get this working?
Steve
electricfox
electricfox's picture
Last seen: 5 hours 19 min ago
If you meant Vcell min in Vesctool Motorsettings -> general -> BMS with VESC BMS selected you will need to update to latest beta 6.06 Firmware or wait for the release. There were some things fixed with this topic.
