Erpm effect on power.
TONY61
Last seen: 2 months 1 day ago
Hi can anyone tell me, if you have a bldc motor designed and rated for say 4000 rpm, and you drop the erpm to max it at say 3000 rpm, will there be a drop in power? Or will the vesk give the same amps but just at the lower erpm?
Regards
Tony
Groundspeed100
It should just limit the speed of the motor. The current is controlled and limited separately.
