Odys Alpha X3 Pro Settings
flashice
Hi there,
I am all new to this. I replaced the stock controller with a Flipsky 75100. Went truh the motor wizzard with a ebike motor (as seen in a video). The motor is spinning and was detected. Then I set up the the throttle and the brake, it was also detected. Then, when I was testing it with the throttle it started spinning, but then stopped and everything was turned off and there was a smell of something.  I first thought, that I blew something up. After disconnecting the loop key and putting it in again, it started again and was controllable vie the throttle. But I have no clue what the right settings are and where to find them.
Could someone help me with that? Or tell me where to find the right settings and where to put them in the vesc tool?
thank you
Ricky
