Phase voltage sensor plausibility check
tecmarek
Hello everyone,
I am currently designing my own vesc hardware.
Now my question is, if the voltage readings also have a plausibility check, similar to the current measurements, implemented in the firmware? So that a disconnected or stuck sensor signal can be detected by the firmware or do I have to safeguard against such failures in hardware.
