Disable wrong FET temperature sensors
Flo98
Last seen: 2 months 1 day ago
Hey guys! I am having wrong sensor readings. Temperature MOSFET 1 and 2 are oscillating around 200 Celsius degrees, and MOSFET 3 is constant at 25 degrees. The VESC is at rest and is not hot when touching it. I get Temperature MOSFET Error (MOSFET temperature maxiumum is set to 190 Celsius degrees in VESC Tool).
How can I disable in the firmware MOSFET 1 and 2 ? There isn't such an option in VESC Tool so i need to customize firmware, or a change in VESC Tool to add this option?
I am using Maytech 75/300
Thanks a lot !
Florian
PS: sometimes, i cannot even connect my VESC to the computer (the high temperature MOSFETS seem to prevent the connection?)
