Using VESC with Ardio and PPM
gjackson
I have the task of reverse engineering a control system that uses a VESC driver with incorporating the the PPM mode of operation.
Currently I am getting the Ble, Green, and flashing Red LED.
Does the flashing LED mean the the driver board is bad?
Thank you for your help.
electricfox
electricfox's picture
Last seen: 53 min 42 sec ago
It means you have a fault. In Vesctool->Terminal->Print faults.
