Available connectors
nopf
Hello again,
I want to know the type of connectors and the possibility to buy.
The packages does not contain the connectors for using ADC.
As I wrote ( other part in the forum ), I failed with PPM and so I try to use potentiometer for power control.
But unfortunately there was no 7-pin connector cable with the controller and I do not want to solder on the board.
I hope I can use forward and reverse with one poti ( or analog voltage ) in ADC input.
nopf
nopf
Update:
I measured the pin distance, the connector and found JST PH 2.0  Connector 2-10 Pin 2,0mm Micro.
I ordered some and I hope it fit.
According my old posts with thw PPM-Issue I tried an older Graupner RC from a friend and what a wonder - does not work.
The solution ist not reaaly cool to make it with servos coupled potentiometers.
This will be last chance. ----- another failure the controller walks to garbage. What a FUXX.
tobiokanobi
Last seen: 12 months 2 hours ago
Dear Nopf,
JST PH2.0 is correct.
-Tobias
nopf
so - being stupid and trying to control each motor separate by using both adc input and a potentiometer for each side
Hmm the controller offers no way to separate the both sides. My VESC has no switch to cut the can.
Using the wizzard is to fail - one try lets both motors run, but far away from an acceptable sync.
Doing the app separately, the other channel forget settings.
I want to go forward and reverse - no success, even I choose centered setting and the tool says ok.
so many wasted hours..........
tobiokanobi
Do you have a schematic of what you want to do?
