VESC 6.05 Fault Coded under Voltage
amblerev
Last seen: 1 year 12 months ago
I have tried to review the other postings on this subject, but no fix has worked,...... I am using VESC 6.05 with a STR500 being fed by a 18650 3000mah cell pack in a 24p12s config, Right now the pack is at 84.7V.On the live data, everything seems fine until the motor hits ~65 percent duty cycle, at which point the STR500 goes into Under Voltage fault. I have adjusted the Nominal Min Voltage all the way down to 0 volts, does not appear to be having any impact. Can anyone advise what other parameters can trigger this faullt?
