Setting RPM over UART
klay2000
Last seen: 1 week 23 hours ago
VESC FreeVESC Platinum
Hello everyone,
I am currently attempting to send some packets to an FSESC 4.20 running firmware 6.02 over UART in order to set RPM, however I'm running into some strange issues! I started by sending the command to get values and parsing the response, which I have confirmed contains the correct data. Next I tried setting the rpm, doing this didn't seem to have any effect at all, so thinking maybe something was wrong with how I was handling multi-byte commands I decided to send the command to request specific values which contains a 4 byte mask making the packet the same length as the set RPM packet. Trying this, I recieved the expected return packet with the requested values. From here I thought maybe I couldn't set values on the ESC for some reason, so I sent the command to set current and yet again nothing happened. Also note that I can get the motor I have attached to spin just fine via VESC Tool connected with USB.
From this it seems to me that I can read values from my device but cannot set them? Am I just missing some sort of safety option set in VESC Tool?
Thanks in advance for any advice anyone might have!
