aggressive throttle
Sandro luis
Last seen: 3 weeks 3 hours ago
aggressive throttle
Guys, I need some help, I'm using a Flipsky 7070 motor in my setup, with a vesc 75100, and a 48v battery only, this motor has a 13-tooth gear, along with a larger 60-tooth gear, to make a reduction , and in this 60 t gear, there is an 11 t pinion, connected to a 54 t ring gear, like a mid drive cyc system, and the question is, why can't I make a uniform acceleration, at the minimum movement of the accelerator, at The start is instantaneous, and this is causing the 11 t pinion clutch bearing to break!  I need an acceleration that starts slowly and increases in seconds but without jerking!!  I've done everything, from increasing the pattern from 0.30 seconds to 2 or more, I've already changed the acceleration curve but it still gives a small initial jerk, what else could I change in vesc tools?
