Vesc 6 mkV interference
PredatorRTX
Hello, I'm new here and I have a problem, maybe you can help me solve it: I have 2x vesc 6 mkV pcb 21700 tramp box, and I have a problem, I have updated the vesc to almost the latest version and I have a problem, but I don't know if it's a software issue, namely my problem is this that when I turn on the box with the button, the main vesc turns on/lights up, while when I turn off the box with the button, the additional vesc lights up, the tramp advised me to move the cables so that when the box button is turned on, two vescs light up, turn off the power from the button and spin both wheels with your hands what will happen is that the power switch will light up and synchronization of 2x vesc/engines will take place, but the question is whether this problem will stop so as not to disconnect the additional vesc, because when I fastened the box with screws, after 15 minutes the vesc/engine immediately disappeared from the vesc tool application when scanning . Any advice on what it could be and how to eliminate it?
