self-built FW does not work properly with VESC Tool?
Jackl
Hi there,
I am trying to do some FW modifications and test some temperature-sensor related things.
So far, most things seems to work. I am able to build fw with for example "make 75_300_r2_no_limits". I am flashing the FW with a ST-Link directly.
It basically works and I am able to control the motor via the VESC-Tool, eg. current commands, etc. What does not work yet:
- When I connect to VESC Tool, I get the message, that I am running a test-build and a non-test VESC Tool.
- When I try to write/read motor/app settings it does not seem to do anything. Neither Read nor Write. I also dont get the "appconf read ok" or simmilar in the bottom right.
What am I missing? I tried following the readme step-by-step and should be good?
Jakob
