PPM, REWIND and FORWARD in same rotation
electrichydrofoil
I convert a Mercury 9.9 to electric.
Propeller direction ist switched with the outboard gear, so the electric motor must spin only forward.
The Throttle should work like in a motorboat, with neutral, forward and reverse.
I am looking for a Setup of the PPM using Centered Control, but in both direction of the Throttle, the Motor should spin forward.
Is this possible?
Thank, for any Help
Max
