Configuration Issue with Dual FlipSky 75100 Controllers
daktylus
Hello everyone,
I'm a new member of this forum and I'm facing some issues with my dual motor setup using two FlipSky 75100 controllers (aluminium PCB). I hope someone could help me resolve these problems.
When I connect the second controller and try to configure the throttle, I receive a message prompting me to perform an update. I've tried to update it, but it didn't work. However, when I unplug the second controller, I can configure the throttle trigger without any issues. Will the configuration automatically transfer to the second controller?
Furthermore, I've noticed that the throttle response is less aggressive than expected. My previous controller had a more pronounced acceleration at startup. How can I maximize the acceleration? I'm relatively new to this field, and I can't seem to find the necessary information to make the appropriate adjustments.
I'm using a TI 30 with 60V motors rated at 2800W. Any help or advice would be greatly appreciated. Thank you in advance!
