Programmable freewheel function
baumeister
For a project it would be an advantage for me if I could operate the motors with a freewheel function.
At the moment I'm using ADC 1 and 2 as gas/brake inputs, with the Duty Cycle setting.
As soon as I let go of the throttle, the engine slows down, the same applies when it is at a standstill.
This also makes it difficlt to push the vehicle when the controller is switched on.
Is there a way to switch this function off or at least weaken it?
