Sleep timer never gets activated
robertkovax
I'm trying to use the Shutdown Mode function in the App Settings to turn off the Vesc after certain time, however it seems like it never gets activated. Is there any setting that could prevent this function working?
Also, I could not test, but the kickstart wakeup functin should be automatically active after the sleep?
I'm using a simple FOC controller coupled to an ADC input, nothing else. Firmware V6.02 on a Vesc 6  MK VI HP.
robertkovax
Ok, so now I did manage to shut down after X_sec time (had to connect the power switch pin to GND permanently for this to work), however its not waking up on kicking or rolling. What do I need to enable to react to the IMU wakeup?
