VESC UART response format?
dcode
Hi folks!
Currently getting started with VESC and trying to communicate with two of them via UART, but the response data I am seeing doesn't make sense to me. I've looked at various Arduino libraries and the sources of the bldc firmware (using 6.05 beta here) as well as vesc_tool itself, and these seem to stick to a strict response format, but that format is not what I am seeing. For example, when I request the firmware version with
id=2, length=1, packet_id=COMM_FW_VERSION=0, crc=0 0, end=3
-> 2 1 0 0 0 3
the response is
2 36 6 65 19 250 221 53 213 45 50 25 37 8 84 154 57 38 130 0 8 0 64 0 0 45 105
where the initial 2 indicates a one-byte length, but 36 isn't the correct length. And so it continues: The packet_id should be COMM_FW_VERSION=0, not 6, etc.
Similar for packet_id=COMM_GET_STATS=128
getStats mask=0, VESC responds with 2 65 0 0 34 55
getStats mask=1, VESC responds with 2 66 0 0 64 154 121 84 151 26
getStats mask=3, VESC responds with 2 67 0 0 160 211 43 92 130 226 127 171 3
where none of the responses match the format I'd expect. Overall, though, the VESC accepts the request messages, which would not be the case if, say, the CRC was wrong, just the responses seem weird. Any ideas what I'm doing wrong?
Darkgayo
I try to use my arduino 32u4 with my Ubox V2 75v 100A j but the arduino library doesn't work properly! All variable change to "0" value with GetMCconfig ang SerMCconfig commands.
any idea? Thanks
rafeh1
anybody get a bt serial tool working on android
rafe
