new to vesc having all sorts of problems
Nic.karpik
little background.
initially had an issue with motors turning off when throttle hit 100% for 1 or 2 seconds. re ran the motor detection wizard and this issue went away but now i have new problems.
esc is a makerx dv4s
motors are from a boosted board.
with the board powered up if i turn on the remote for the first time the motors kick on for a second. not huge problem but potentially a sign of other issues.
second issue, with the board on a bench if i run the motors i can hear what can only be described as hiccups. i'll attach a video for reference.
https://share.icloud.com/photos/024EDd7Pib_E6_B-5cm-nJvOA
