Throttle movement
Lasse
Throttle movement
Hello
I have problems with the throttle movement.
If I have no restriction on the rpm (Motor settings/general/Max Erpm) then all my throttle movement works, i.e. if the throttle trigger is not pressed, the engine stands still as it should and if the throttle trigger is fully pressed, the engine revs at full rpm. The full throttle movement is used. 0-100%
But I need to have a speed limit. If I reduce Erpm, the throttle movement is also reduced by the same amount, about 0-30%, which means that 30-100% is not used. This means that the sensitivity of the throttle movement is reduced.
I would like the full throttle movement used to my max Erpm
How should I do?
grateful for answers
Lasse
