What VESC Controller should I buy?
Skye Parker
Hey everyone!
Looking for some advice on my rideable "swervedrive" robot project.
This will be a platform with 4 hub motors, each with its own steering motor. I am looking to bench test the hub motors with power running through slip rings. Anyway, I just want to use these baby hub motors:
https://www.monsterscooterparts.com/trsc/rec-categories/motors1/rear-whe...
I want to test running them with the hall sensors and also sensorless.
As you can see the motors are very low power. Only 80 watts. Can anyone recommend what controller I should buy?
VESC 6 Edu if you are below 6S Lithium. https://trampaboards.com/vesc-6-education--c-2335.html
