Simultaneous control of two BLDC motors with VESCs via CAN bus without RC controller
sampatsr
Greetings!
I wanted to inquire about the operation of two BLDC motors (Maytech Brushless 5065 190 KV) connected with FLIPSKY Mini FSESC6.7 PRO using CAN Bus via the VESC tool software.
So, currently, we are able to connect both the VESCs with the software and we are able to individually control the motors with the software. But our target is to simultaneously control both the motors at a set speed. Based on our research we have come across some resources that have exhibited simultaneous control via CAN bus. However, in all these cases, a RC controller was used to configure the VESC and run the motors simultaneously. Hence, we would like to know if it is possible to control both the motors simultaneously with the software via CAN Bus without using a RC controller.
Thanks in advance!
