Help i have no idea how it works...
Xtracker133
Hey guys i ordered Flipsky 75100 controller running firmware 6.0 i paired it with 56.4V battery 13S5P + M365 PRO motor.
I wanted more speed something around 43km/h but no even if it has 80A limit and more voltage still runs 35km/h like stock xiaomi from the shop whats the point ? i need better motor ?.
Thanks guys
oangelo
Last seen: 7 months 5 days ago
Can your battery supply 80A? I guess not. It would take a very beefy battery to supply such high current. Look at the "Realtime Data", it will show how much current the battery is supplying and how much current the motor is using.
I do not belive the seller would design a battery that can handle more current then the intent machine needs, would be more costly. I think the problem might no be the motor, but the battery, or both.
Xtracker133
Hey my battery is custom build from scratch 13S5P BMS is 40A max so if i supply 40AMPS it is good.. acceleration but still duty 98% and 34km/h max..
