Help needed in controlling multiple VESC boards (multiple motors) with VESC ROS (need to debug errors)
shreyas.srinivasan
I modified the following files in VESC ROS : https://github.com/sbgisen/vesc to get the proceeding errors when I was trying to control 2 motors using the VESC ROS Interface.
Modified code of "velocity_control_sample.launch":
<launch>
<!-- Controller -->
<arg name="model" default="$(find vesc_hw_interface)/launch/test.xacro"/>
<param name="robot_description" command="$(find xacro)/xacro $(arg model)"/>
Boot hardware interfaces -->
<node name="vesc_hw_interface_node_1" pkg="vesc_hw_interface" type="vesc_hw_interface_node" output="screen">
<rosparam>
joint_name: arm1_joint
command_mode: velocity
port: /dev/ttyACM0
num_motor_pole_pairs: 10
gear_ratio: 1
torque_const: 1
</rosparam>
</node>
<node name="vesc_hw_interface_node_2" pkg="vesc_hw_interface" type="vesc_hw_interface_node" output="screen">
<rosparam>
joint_name: arm2_joint
port: /dev/ttyACM1
gear_ratio: 1
torque_const: 1
</rosparam>
</node>
<!-- Boot ros_controllers -->
<rosparam>
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 100
<!--joint_velocity_controller_1:
type: velocity_controllers/JointVelocityController
publish_rate: 100
base_frame_id: base_link
joint: arm1_joint-->
joint_velocity_controller_2:
publish_rate: 100
joint: arm2_joint
publish_rate: 100
joint: arm1_joint
</rosparam>
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false" output="screen" args="joint_state_controller
joint_velocity_controller_2"/>
</launch>
Modified code of "test.xacro":
<?xml version="1.0"?>
<robot name="vesc_test">
<link name="base_link"></link>
<joint name="arm1_joint" type="revolute">
<parent link="base_link"/>
<child link="arm1_link"/>
<origin xyz="0 1.36 0" rpy="1.57 0.0 0.0"/>
<axis xyz="0 0 1"/>
<limit effort="100" lower="100" upper="100" velocity="100"/>
</joint>
<link name="arm1_link"></link>
<joint name="arm2_joint" type="revolute">
<child link="arm2_link"/>
<origin xyz="0 -1.2 -0.25" rpy="0 0.0 0.0"/>
<axis xyz="0 0 1"/>
</joint>
<link name="arm2_link"></link>
</robot>
Error when I do roslaunch : "roslaunch vesc_hw_interface velocity_control_sample.launch":
process[vesc_hw_interface_node_1-1]: started with pid [22176]
process[vesc_hw_interface_node_2-2]: started with pid [22177]
process[controller_spawner-3]: started with pid [22178]
[ INFO] [1665065249.028335730]: Joint limits are loaded
[ INFO] [1665065249.035389428]: Gear ratio is set to 1.000000
[ INFO] [1665065249.035460946]: Torque constant is set to 1.000000
[ INFO] [1665065249.035497194]: The number of motor pole pairs is set to 10
[ INFO] [1665065249.036451237]: mode: velocity
[ INFO] [1665065249.036777679]: Joint limits are loaded
[ INFO] [1665065249.040281165]: Gear ratio is set to 1.000000
[ INFO] [1665065249.040330125]: Torque constant is set to 1.000000
[ INFO] [1665065249.040347934]: The number of motor pole pairs is set to 10
[ INFO] [1665065249.040991319]: mode: velocity
[INFO] [1665065249.453687]: Controller Spawner: Waiting for service controller_manager/load_controller
[INFO] [1665065249.457591]: Controller Spawner: Waiting for service controller_manager/switch_controller
[INFO] [1665065249.463098]: Controller Spawner: Waiting for service controller_manager/unload_controller
[INFO] [1665065249.467841]: Loading controller: joint_state_controller
[INFO] [1665065249.480781]: Loading controller: joint_velocity_controller_1
[INFO] [1665065249.500746]: Loading controller: joint_velocity_controller_2
[ERROR] [1665065249.507634155]: Exception thrown while initializing controller 'joint_velocity_controller_2'.
Could not find resource 'arm2_joint' in 'hardware_interface::VelocityJointInterface'.
[ERROR] [1665065249.507716149]: Initializing controller 'joint_velocity_controller_2' failed
[ERROR] [1665065250.509234]: Failed to load joint_velocity_controller_2
[INFO] [1665065250.511685]: Controller Spawner: Loaded controllers: joint_state_controller, joint_velocity_controller_1
[INFO] [1665065250.520736]: Started controllers: joint_state_controller, joint_velocity_controller_1
When I do "rostopic list", I get the following topics:
/canary
/joint_states
/joint_velocity_controller_1
/command /rosout /rosout_agg
When I do "rostopic pub /joint_velocity_controller_1/command std_msgs/Float64 80", I am able to do velocity control for one motor.
When I do "rostopic pub /joint_velocity_controller_2/command std_msgs/Float64 80", nothing happens, and am not able to control velocity for the other motor. Please help me in solving this.
