Encoder maximum PPR/CPR
Michelle90
Hello.
I tried to find an answer but no luck, so I ask here: Have VESC any sort of limit / max value of encoder (ABI)  it can use? I see some people using 2500 ppr just fine, but what about higher values? Things like 5000ppr or even 10000ppr (which is 40000cpr) would still work? Asking because I would like to run a bldc motor in slow rpm but high precision axis application using vesc.
Thanks for info!
