Sending Negative Values to VESC over CAN bus
olivierabristol
I am currently working on a winch with multiple ESC. As I need to go forward and backward, I send positive and negative commands over CAN to VESC. to go forward, no problem.
Problem is for backward motions, it does not works really well , the motor can go backward but with it's maximum allowable current... Does somebody already face this issue? How does you solved it ?
