Higher voltage DRV error
jarrow
Hi all,
I build my VESC with HW 4.12 about 2 months ago and after some failures, like a burned DRV, I have it running my Turnigy SK3 149kV motor.
The problem: when I connect one 5S battery it works flawlessly, like you'd expect. Yet once I add a second battery in series to a total of 10S I get a DRV8302 error... When I switch back to the 5S config no errors at all.
My voltage limits are set from 8V to 57V and I don't get a overvoltage error but a DRV error.
What could be causing this? Will post settings if needed when I have access to them
