Maximum Motor RPM will not reached
Skyver
for a new project i decided to use BLDC motors, this is the first time i work with BLDC motors and now i can't get any further.
I set up the motors and input with the wizard as described in many videos.
I use a Flipsky 6384 190KV with Flipsky Mini FSESC4.20.
At 44V and 190KV the motor should make 8360 RPM?
I measured the RPM and the motor is only making about 2500 revs.
In the most of the videos mention that incorrect settings can destroy the VESC, I don't want to work with try and error here.
In the Input Setup Wizard, under PPM configuration, I found the setting PID Max. ERPM. The value is set to 15000, increasing this value makes the motor spin faster.
Can I slowly increase the value until the motor is running at the target speed. without killing something.
Or is there somewhere, another setting to increase the RPM.
Thanks in advance
