SSI Encoder with VESC
tsharma
Hi Everyone,
I am using VESC6 MKV and I am using it for the position control of a SPMSM. The encoder attached to the motor is a SSI Encoder. However, the VESC supports Hall Sensors or ABI or SPI interface.
Is there any possibility that I can use, SSI encoder with the VESC board?
Or if I can use any: "Asynchronous serial, BiSS, PWM, SSI" of these with VESC?
Any help will be appreciated.
onur_er
I am also looking for an answer to the same question. If there is anyone with the experience, can you please help?
