PAS pinout
sifourquier
PAS pinout
Hello
I want use ADC and PAS app but in not found the pinout for break is ADC2
But where i need connect quadrature sensor?
if you can help me thanks you.
velolac
I have run into the same problem, and asked in another topic, but no answer. I checked the code on github and I believe the Rx and Tx ports shall be used for signals and 5V and GND. I havent tested it yet as I have just lately received the quadrature IC sensor. Too bad, that if you connect it wrong or simply short something than you may burn an important IC inside the VESC.
It would be nice if there would be a manual from Trampa where the experts go through all the supported apps and give the pin layout for them.
