Smooth Throttle
acsports
Smooth Throttle
Hello Vesc Forum,
at first, we would make a big hug to Sebastian who invented this device. We are building the Carryboard, a Golf Skateboard specialy manufactured for Golf courses.
Without this device, it would not be possible to use our Board, so big big thanks.
Config:
Battery --> Y Cabel --> 2 Vescs (Firmware 4.2, Vesc Tool 2.03) --> Brushless Motor 48 V Mid Size
ADC --> Thumbthrottle
We want a smoother throttle for our clients. The throttle is quite Heavy, because we also have a big gear wheel.
To be honest, we just can configure what we minimal need that our Board is working as it should.
Pls tell us what you need for further investigation.
Many thanks in advance.
David Hermsdörfer
AC-Sports UG
www.ac-sports.de
ccci
Maybe I can help you, I think that you need the throttle to output PWM signal, if throttle only interacts with ADC that means it has analogue signal out, there are a many ways to convert the signal to PWM to get smoother acceleration. If you have more questions always welcome to contact me at i@ccci.io
