motor stuttering and having a hard time with receiver ... help
okyuubix
Issue :
 When using the Receiver(Flipsky v2) to test the FWD/BWD ... the wheels don't go fwd and both motors make sounds but aren't turning.
Tho going back ''works'' but having a little hard time maintaining.
*The motors tho are running well when I do the detection test
When I try to setup the Input I do not see any feedback from the receiver in vesc ...
RT & RT APP are both activated ...
Im not able to pin point the source of the issue please help
Parts :
-12s3p 40T Complete Battery Solution
Nominal Voltage: 44.4V
Capacity: 12000mAh
Power: 518.4Wh
Cells: Samsung 40T
Connection: XT60 Female connector
Max Discharge: 60a
-Dual FSESC6.6 Based upon VESC6 with Aluminum Heatsink
-Screen Remote VX2 Pro
-BELT MOTOR 6374 190KV 3500W
Max Power: 3500 Watts
Max Current: 85 Amps
Max Volts: 12S
Max Torque: 8 Nm
Motor Resistance: 0.05 Ohm
-Kegel 80mm wheels
