Updating App and info xml failed
Pimousse
I'm in the process of building a custom firmware to disable NRF module (too much 2.4Ghz devices in a close space, Bluetooth connection is not steady).
I modified app and info xml files to match my new parameter (and those modified like the FW number) but the changes seem to not be saved (even if I click on the disk and I get the green ack).
I tried to run VESC Tool in Sudo permission, but no luck.
What do I miss ?
Thanks,
Cheers,
Clément
