Incorrect speed too high
Michele84
Last seen: 4 years 2 weeks ago
Hi guys, I have installed stormcore 100D on my 11X zero escooter. I opened the engines and installed the hall sensors. For now, everything seems to be going well in FOC mode. I set a limit of 18000rpm but from the stormcore app I find a too high speed of about double! 106km / h! The motors are 11 '' and the wheel measures 260mm.
The data on vesc are:
Motor pole 15,
gear ration 1,
Wheel diameter 260mm.
What am I wrong? What should I do to get the correct maximum speed value? Thank you !
