Startup codes?
anthonys
Startup codes?
Hi, I'm just getting started with a VESC 6 Mk V, running the f1tenth 5.2 software (with servo out enabled). Where can I see a list of fault codes? I'm getting 17 red flashes on startup, repeated once. When I connect the VESC to the vesc-tool and type "faults" in the terminal the response is "No faults registered since startup". Thank you.
