General question on tuning vesc
stevo11811
Last seen: 12 months 1 day ago
I'm rather new to VESC due to the fact that i cannot leave anything alone, so far super pleased with the performance vs my old china ESC but i'm left with a few questions i cannot find answers to.
Setup -
Electric Skateboard -
2x Hub motor
10S2P Samsung 40T Cell's.
Hub Current = 40 ea
Hub Regen = 35
Batt Current max = 32
Batt regen = 20
Mode = FOC, hall sensor
Firmware 5.03 - 5/29/2021
I'll post more screenshots when i have the board back together of the settings but i was more interested if this is normal to see during a top speed run with field weakening.
at 91% duty cycle i start field weakening and the current (batt) and power (watt) drop off. Should i be seeing a power drop during field weakening while the hub current stays the same? or is this what happens when the motor is at its maximum.
Max duty is 95%, i moved the D Axis gain scaling and duty cycle current limit start to 94%.
Just to be clear it drives very very smooth and has great power/top speed but i'm not sure if its actually "Correct".
I only hammered the throttle after a few corners.
Run1
Run2
