no effect on set erpm/speed limit
xenon321
I have the problem that when i set the speed limit in the profiles tap and set it to "use until Reboot OR Use permanently"
this setting is completely ignored and i got always max speed.
Here are my setup:
Vesc 100/250 @16s FW.:5.2
8Kg 10 pole inrunner
1:7,6 Gear ratio
Wheel Daimeter 640mm
I have set everything up again several times without success
I am at the end of my knowledge.
Update:
now i spend a couple hours to find a workaround and find that when i use The ADC Control Type :"PID Speed" the eRPM limits are working but only there current and duty cycle the eRPM limits will be ignored.
but why?
