Help rc car bldc configuration vesc 4.20
Katt
Hy guys, i have a vesc 4.20 connected to a 1200kv 4 pole in bldc mode sensorless powered at 12S. This motor has a low inductance. Could someone tell me how to set esc for rc application? Thank you very much
Katt
Seems that nobody can help me. I find a minimal setup thath makes rotate motor without esitation but i have a strange problem. Controller seems do not understand control mode. If i use duty control after ppm calibration when i push the gas to 20% duty rise without control to max. I try current control and all control mode but the behaviour is the same. Can someobe help me? Is there any connection to realize? Luca
spacewalker
Duty cycle   is   working  while  driving / load
on the bench  - it will speed up maximum
you should use PPM and current
Martin
