What are the meaning of some of the MCCONF values...
jackherer
When looking at the firmware code in order to develop a custom firmware version, I have found most of the code to be self expanatory.
But there are a few defines that are bugging me.
So firstly what is MCCONF_L_IN_CURRENT_MAX in mcconf? I am not sure if its for the max current from regen braking back to the battery or if its max current from the battery into the controller.
Last seen: 1 week 4 days ago
Its the max input current from the battery
#ifndef MCCONF_L_IN_CURRENT_MAX
#define MCCONF_L_IN_CURRENT_MAX             60.0    // Input current limit in Amperes (Upper)
#endif
#ifndef MCCONF_L_IN_CURRENT_MIN
#define MCCONF_L_IN_CURRENT_MIN             -60.0   // Input current limit in Amperes (Lower)
#endif
jackherer
Ahh, so the MCCONF_L_IN_CURRENT_MAX is the current from the battery and  MCCONF_L_CURRENT_MAX is the current from vesc to motor?
// Limits
#ifndef MCCONF_L_CURRENT_MAX
#define MCCONF_L_CURRENT_MAX			60.0	// Current limit in Amperes (Upper)
#endif
#ifndef MCCONF_L_CURRENT_MIN
#define MCCONF_L_CURRENT_MIN			-60.0	// Current limit in Amperes (Lower)
#endif
#define MCCONF_L_IN_CURRENT_MAX			20.0	// Input current limit in Amperes (Upper)
#endif
#define MCCONF_L_IN_CURRENT_MIN			-20.0	// Input current limit in Amperes (Lower)
#endif
#ifndef MCCONF_L_MAX_ABS_CURRENT
#define MCCONF_L_MAX_ABS_CURRENT		70.0	// The maximum absolute current above which a fault is generated
So what are the MIN values for then?
thanks
JamieJackHerer
hideo040401
MCCONF_L_CURRENT_MAX its for the current going into the the motor
and MIN is for the minimal current input but if the value below 0 it will be for the max current for the regenerative braking
