Motor FOC + ALL self-study to all CANBUS devices
Filcas
Last seen: 10 months 3 days ago
Hello guys,
Will it be possible to run a command line or add a custom button to the VESCTOOL to keep all the motor settings but update the FOC PARAMETERS and HALL SENSOR tables on all devices connected through CANBUS at same time?
This will be similar to the default WIZARD, but we would like the same command not to change the settings on each of the devices connected on the CANBUS, but just update the FOC parameters and hall sensors table.
Is there a way or any workaround you guys might know to achieve this? Thanks in advance.
