Spikes in RPM causing the ride to be bumpy
dsuresh
I am having an issue where I am running my motor off a 40V Ryobi battery and using a potentiometer to control the speed of the motor. When I am monitoring the VESC tool for check the RPM, I see that there are spikes every 15 seconds which reduces the speed (-50 from the regular speed) but the motor is back to its normal speed after a seconds to two. I checked it with 2 different fully charged Ryobi batteries and I am having the same issue. I am using VESC MKV6, Ryobi battery 40V 4Ah for my application.
I will post the images shortly from the vesc tool
