VESC Connections
shatty
VESC Connections
Im replacing the ESC on my Ninebot G30 Max with a 75V VESC.  I am confused about the connections.  How do I know which Hall sensor wire go with each phase?  Im assuming H1 is Phase A, H2 is B and H3 is C.  I have a brake light that flickers when you squueze brake and stays on when scooter is on.  Where does that get connected to?  Its a 2 wire.  Throttle connects to PPM/5V/GND.  What about the hand break which is also a 3 wire?  How does that get connected?  Front led headlight connects to 5V output.  Which do I use for tha? And my addon LED goes to 12V output. I see a 12v/GND/AUX connector.  Whats the AUX pin for?  I ordered a kit of JST PH connectors.  Is there a list of what each connector does?
